9 years, 3 months ago.
Pushing code into LPC824 using LPC1768
Anyone have sample of a program to push code into LPC824 (in the bootloader mode) using LPC1768?
Our theory is that we write a program for LPC824, compile and bin/hex then find a way to import bin/hex into LPC1768 in a "push program" so that when i connect LPC1768 to LPC824 (with reset ping, bootloader-pin, UART0 RX and TX) the LPC1768 must detect the high on bootloader-pin , pull bootloader-pin down, reset the Lpc824, and start pushing the "embeded code" into LPC824
I understand this is what flash magic does. Flash magic is not free for prod use and this method will be super easy "on the field"
I am also sure many in this forum will have much better ideas. So please help us with your ideas too.
Any other preexisting hardware that can do this?
Best Regards Surendar
Please try this! >>> https://developer.mbed.org/users/okano/code/ika_shouyu_poppoyaki/
(Thank you Watarai-san, for letting me know this question entry)
Okano-San,
If I dont use the mbed hardware and use my own custom lpc1768, what is the easiest way to "emulate" the hard drive?
Reason is I can get custom lpc1768 breakout boards for about $15.
posted by siva surendar 07 Jan 2017
