9 years, 4 months ago.
Nucleo_printf uart example not working
I bought the Nucleo-F767ZI board and tried to flash the uart example called nucleo_printf. I downloaded the code from the mbed compiler and flashed it using openocd. Unfortunately nothing happens, not even the LED is blinking.
Deleting all the code related to the uart, the LED is blinking properly.
Someone can help me?
Thank you in advance, Thomas
STM32 Nucleo-144 development board with STM32F767ZIT6 MCU, supports Arduino, ST Zio and morpho connectivity
I am getting the same problem with STM32L011K4. in the compiling stage it is showing some error.
I don't get any errors in the compiling and fashing process.
posted by Thomas Zeschg 13 Dec 2016
Hello I've the same problème when il use the exemple. But it's OK when i creat à new project with the same program main () But when i want to attach a method from a class, thé result is not ok. Exemple : This is Ok :______________
  1. include "mbed.h"
DigitalOut myled(LED1); Serial pc(USBTX,USBRX); Serial test(PC_6,PC_7); void pcrx(void) { if (pc.readable()) test.putc(pc.getc()); } void testrx(void) { if (test.readable()) pc.putc(test.getc()); } int main() { pc.baud(9600); pc.attach(&pcrx,Serial::RxIrq); test.attach(&testrx,Serial::RxIrq); ....
This is not ok before os 5.......................................................... Wifly is a class... void Wifly::handler_rx(void) { read characters while (wifi.readable()) buf_wifly.queue(wifi.getc()); }
void Wifly::attach_rx(bool callback) { if (!callback) wifi.attach(NULL); else wifi.attach(this,&Wifly::handler_rx,Serial::RxIrq); this is on error }
