9 years, 3 months ago.
LPC1678 SPI interface with RC522
Hello ,
i am trying to interface LPC1768 with RFID reader RC522 over the SPI port.
i am getting response as 0x21 . i have attached code for your reference.
i am unable to read the RFID.
  1. include "mbed.h"
SPI spi(p5, p6, p7); mosi, miso, sclk DigitalOut cs(p8); int main() { Chip must be deselected cs = 1;
Setup the spi for 8 bit data, high steady state clock, second edge capture, with a 1MHz clock rate spi.format(8,3); spi.frequency(1000000);
Select the device by seting chip select low cs = 0; while(1){ Send 0x8f, the command to read the WHOAMI register int whoami= spi.write(0x8F);
whoami = spi.write(0x00); printf("WHOAMI register = 0x%X\n", whoami);
} Deselect the device cs = 1; }
Please use <<code>> <</code>> tags to make your code easier to read.
Try again with:
spi.format(8,0); replace your spi.format(8,3);
reviewing this detail from here:
https://developer.mbed.org/users/AtomX/code/MFRC522/docs/63d729186747/MFRC522_8cpp_source.html
Please also study this example:
https://developer.mbed.org/users/kirchnet/code/RFID-RC522/
Do you have the RESET pin mapped on the RC522 ?
include "mbed.h"
SPI spi(p5, p6, p7); // mosi, miso, sclk
DigitalOut cs(p8);
//Chip must be deselected
cs = 1;
//Setup the spi for 8 bit data, high steady state clock, second edge capture, with a 1MHz clock rate
spi.format(8,3);  // test with spi.format(8,0);
//Select the device by seting chip select low
cs = 0;
while(1)
//Send 0x8f, the command to read the WHOAMI register
//Deselect the device
cs = 1;
