9 years, 1 month ago.
Save sensors data to SD
Hi, i have questions about save data to SD.i use LPC4088 board. Could someone can give me an example to let me know clearly? And i would like to save bit file to SD. Just like Hex. Thanks very much!!!!! Thanks! These are sensors below.
void sensorA();
void sensorB();
void sensorC();
int main(){
      sensorA();
      sensorB();
      sensorC();
SD interface = SPI interface.
You should be able to use the following mbed code for your project:
https://developer.mbed.org/teams/mbed/code/SDFileSystem/
// Access the filesystem on an SD Card using SPI
#include "SDFileSystem.h"
// change the port pins to suit the SPI port pins on your target board
SDFileSystem sd(p5, p6, p7, p12, "sd"); // mosi, miso, sclk, cs
    FILE *fp = fopen("/sd/myfile.txt", "w");
    fprintf(fp, "Hello World!\n");
    fclose(fp);
THx !! i will try
posted by jajn HA 27 Nov 2016
