9 years, 4 months ago.
How do I increase Arduino analog output current to 0.5A and still have variable voltage output
Hi I need to simulate a pump control system that uses a rheostat to control the pump motor speed.
With readings from a multimeter and trials with a variable power supply, I can control the pump motor speed when I set x Volts @ 0.5A. I intend to use an Arduino board for this purpose but is unable to increase the Arduino analog output pin current beyond 40ma.
Please help.
This is the mbed forum not an arduino one.
You need some sort of amplifier circuit to supply that much current. Something along the lines of this: http://hades.mech.northwestern.edu/index.php/Linear_Amplifier_Motor_Driver
