9 years, 4 months ago.
Problem communication between MBED and USB key
I have a problem with USB communication. I can read the content on the USB key and the content of a file only one time. The second time, the program stops at the message : Connect a Mass Storage device Thank you for your help. i am a beginner in the programmation with the MBED.
Below my program:
include "main.h"
#define FSNAME "msc"
DigitalIn interFA(p27);
DigitalOut led1(LED1);
DigitalOut led2(LED2);
DigitalOut led3(LED3);
DigitalOut led4(LED4);
Serial debug(USBTX, USBRX);
InterruptIn ComutFA(p27); interruption
int valeur,i,j,k,Code,CodeImp,Loop,CodeCW, select,first,prime,adr_sw1,val_sw1,adr_sw2,val_sw2;
int data[50];
int val_int[150];
char ligne[150];
char cmd[2];
float val_float[20];
FILE* fp;
void CONF_MOST() {
debug.printf("Configuration\r\n");
led1 = 0;
led2 = 1;
DIR *d;
struct dirent *p;
printf("\n\r=================================================\n\r");
printf("USB Mass storage demo program for mbed LPC1768\n\r");
printf("=================================================\n\r");
d = opendir("/msc");
printf("\n\rList of files on the flash drive:\n\r");
if ( d != NULL )
while ( (p = readdir(d)) != NULL )
printf(" - %s\n\r", p->d_name);
else
error("Could not open directory!");
led2 = 0;
led3 = 1;
debug.printf("\r\n Open file MOST.txt\r\n");
fp = fopen( "/msc/MOST.txt", "r");
if ( fp == NULL )
debug.printf("File MOST.txt not found in USB key !!! \r\n");
select = 0x6D;
while (val_int[0] != select) {
fgets(ligne, sizeof(ligne), fp);
sscanf(ligne, "%x", &val_int[0]);
// debug.printf("Donnees");
// debug.printf(" = %x \r\n", val_int[0]);
sscanf(ligne,"%x %x %x %x %x %x %x %x %x %x %f %f %x %f %x %x %x %x %x %x %x %x %x %x %x %x %f",
&val_int[0], &val_int[1], &val_int[2], &val_int[3], &val_int[4],
&val_int[5], &val_int[6], &val_int[7], &val_int[8], &val_int[9],
&val_float[0], &val_float[1], &val_int[10], &val_float[2],
&val_int[11], &val_int[12], &val_int[13], &val_int[14],
&val_int[15], &val_int[16], &val_int[17], &val_int[18],
&val_int[19], &val_int[20], &val_int[21], &val_int[22],
&val_float[3]);
debug.printf("\n\rDonnees : %x %x %x %x %x %x %x %x %x %x %1.1f %2.2f %x %1.1f %x %x %x %x %x %x %x %x %x %x %x %x %2.3f\r\n\n",
val_int[0], val_int[1], val_int[2], val_int[3], val_int[4],
val_int[5], val_int[6], val_int[7], val_int[8], val_int[9],
val_float[0], val_float[1], val_int[10], val_float[2], val_int[11],
val_int[12], val_int[13], val_int[14], val_int[15], val_int[16],
val_int[17], val_int[18], val_int[19], val_int[20], val_int[21],
val_int[22], val_float[3]);
fclose(fp);
led3 = 0;
/*Beginning of the program */
MSCFileSystem msc("msc");
CONF_MOST();
ComutFA.fall(&CONF_MOST);
debug.printf("Running \r\n");
while (FOREVER) {
led1 = !led1;
wait(0.5);
} // parenthese du While
} // parenthese du Main
Please edit / repost using
so that the code formatting is correctly preserved.
posted by Andy A 27 Oct 2016
