9 years, 4 months ago.
How to extract this ( KoIEIkCAAACnAAAAIE4AAAAAAAAAAAAA////////9wMAAAACQB) from the CAN bus??
I need help on a task that requires me to extract a key KoIEIkCAAACnAAAAIE4AAAAAAAAAAAAA//9wMAAAACQB from the CAN bus . There is no need to interpret it but I just need to extract this from the CAN bus. The Identifier is 11bit and the Data is 60 byte in all coming from the multiplexers. Could you help me start with this peoject.
kindly advise
Hello Gok,
A single CAN packet can have from zero up to 8 bytes of data. A newer CAN called CAN-FD (CAN with Flexible Data rate) can carry up to 64 bytes in a single packet but according to my knowledge neither the mbed enabled chips/boards nor the mbed CAN library support that.
