9 years, 5 months ago.
Export broken
Export seems to be broken. try clicking export here and you will get a Page error https://developer.mbed.org/teams/MultiTech/code/Dot-Examples/?platform=MTS-mDot-F411 or https://developer.mbed.org/teams/mbed/code/mbed_blinky/export
some can still be exported using the compiler, though the dot example is the one I need, that eventually fails with the compiler export
specifically I want to export the Dot-Examples for the mDot, to Uvision 5.
Thanks
Hi Chris,
We are having issues with exporters at the moment, but these should be fixed very very soon :). Sorry for all of that.
You could try using mbed-CLI, this allows you to pull code from our repositories and compile offline.
https://github.com/ARMmbed/mbed-cli
For the Dot examples use "mbed import'
If you need any help, let me know
Regards, Andrea team mbed
I was able to use the CLI to export and compile it, thanks for the suggestion.
posted by Chris Snow 21 Oct 2016
