9 years, 5 months ago.
Mbed RTOS hangs when starting modem of Ublox
I'm trying to start GSM modem of Ublox C027 and it is succeeding if I'm not using RTOS. But when I add RTOS, it throws the following error: "RTX error code: 0x00000001, task ID: 0x10000B78" and execution stops.
I can't find that error code anywhere in documentations, what it means? I disabled all the other threads so now there is only main and communication thread running. Other threads are working without modem thread so disabling them is only a precaution.
Pauli,
I have gotten the 0x01 error several times. The error codes can be seen in the rtos source files. This is a stack overflow error. You need to allocate more stack size to that thread when you create it is all. Like this:
Thread thread_gsm(osPriorityNormal,4000); //or whatever size you need
And these are the codes:
/* Error Codes */ #define OS_ERR_STK_OVF 1U #define OS_ERR_FIFO_OVF 2U #define OS_ERR_MBX_OVF 3U #define OS_ERR_TIMER_OVF 4U
Graham
