9 years, 5 months ago.
Exchange data over Serial
Hi! I've two mBed systems (a LPC1768 and a FRDM-KL25Z) LPC1768 is the master and KL25Z the slave. Now i need two transfer three float numbers and one integer number from LPC to KL. Now using chars i have did an handshacke but I don't have idea to transfer these data. Thank you really much
This is my sender. Not realised in mbed but maybe you get the idea. On the receiver I use a statemachine to receive the packets. Maybe that helps.
* send.c
* Created on: 18.07.2016
* Author: xdeschain
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "calculation.h"
#include "stm32f4xx_hal.h"
extern UART_HandleTypeDef huart2;
extern UART_HandleTypeDef huart3;
// Send result over serial line to master controller
union uFloat {
uint8_t uBytes[4];
float sFloat;
union uInt32 {
uint8_t uBytes[4];
int32_t sIn32t;
union uInt16 {
uint8_t uBytes[2];
int16_t sIn16t;
union uInt8 {
uint8_t uBytes[1];
int8_t sInt8;
union uBool {
uint8_t uBytes[1];
bool uBool;
Print one char to serial line
void print3(uint8_t c) {
HAL_UART_Transmit(&huart3, (uint8_t*) &c, 1, HAL_MAX_DELAY);
// If I would scale the magnitude to 32000 then the divider must be 14.8
// See calculation.c //conf->magnitude = (float)conf->magnitude * 32000.0f / (float)maxCorelSumValue; // normalize to 32000
// But in order the full magnitude will never be reached, I divide the magnitude by 10.
int16_t scaleMagnetude(long _magnitude) {
// magnitude könnte größer als int16_t max werden.
long lMagnitude = _magnitude / 10;
// check overflow
if (lMagnitude > 32000)
lMagnitude = 32000;
else if (lMagnitude < -32000)
lMagnitude = -32000;
// don't let magnetude be 0 if _magnitude is not. Because 0 means no valid signal
if (lMagnitude == 0 && _magnitude != 0) {
if (_magnitude > 0)
lMagnitude = 1;
if (_magnitude < 0)
lMagnitude = -1;
return (int16_t) lMagnitude;
void sendToMaster(CAL_ChannelTypeDef *confL, CAL_ChannelTypeDef *confR, bool flag_ShowValuesSendToMaster) {
// Header Bytes. Sollten in den Uebertragenen Daten kein weiteres mal so vorkommen.
uint8_t header1 = 0xFF; //Header
uint8_t header2 = 0xFF; //Header
// Sensor links
union uInt16 magnetudeL;
magnetudeL.sIn16t = scaleMagnetude(confL->magnitude);
//magnetudeL.sIn16t=confL->magnitude;
// Sensor Rechts
union uInt16 magnetudeR;
magnetudeR.sIn16t = scaleMagnetude(confR->magnitude);
//magnetudeR.sIn16t = confR->magnitude;
//checksumm
uint8_t checksumm = header1 + header2;
checksumm += magnetudeL.uBytes[0] + magnetudeL.uBytes[1];
checksumm += magnetudeR.uBytes[0] + magnetudeR.uBytes[1];
checksumm &= 0x7F; //B01111111;
//send
print3(header1);
print3(header2);
print3(magnetudeL.uBytes[0]);
print3(magnetudeL.uBytes[1]);
print3(magnetudeR.uBytes[0]);
print3(magnetudeR.uBytes[1]);
print3(checksumm);
debug.print("ML0: ") ;
debug.println(magnetudeL.uBytes[0]) ;
debug.print("ML1: ") ;
debug.println(magnetudeL.uBytes[1]) ;
if (flag_ShowValuesSendToMaster) {
char msg[160];
sprintf(msg, "ML: %i MR: %i QL: %f QR: %f PDL: %i PDR: %i\r\n", magnetudeL.sIn16t, magnetudeR.sIn16t,
confL->filterQuality, confR->filterQuality, confL->peakDistanz, confR->peakDistanz);
HAL_UART_Transmit(&huart2, (uint8_t*) msg, strlen(msg), HAL_MAX_DELAY);
