9 years, 6 months ago.
Missing Callback.h in mbed RTOS
I added RTOS library to my project and tried to compile it. In RTOS/Thread.h there is missing Callback.h and compilation stops.
I then tried to start a new project where I only have Mbed and RTOS included but now compilation stops at missing mbed_error.h in Mutex.h. It really seems that there are some bugs on Mbed RTOS library. Is there any way to solve the problem?
I am having the same issue and can find no solution
posted by Donovan Kuhstoss 12 Nov 2016
If you're on mbed OS 5 (mbed-os library as dependency) you should not add rtos library as it's already included.
If you're on mbed 2.0 (mbed or mbed-dev library as dependency) you should add `mbed-rtos` (not rtos) to your project.
I have created a new project with mbed and mbed-rtos library just now and compiles fine against K64F and F401RE's target.
