9 years, 4 months ago.
Trouble with default constructor, need help
Hello guys, the following code is a part of one header of a MQTT projekt with a Nucleo F103RB device.
class MQTTEthernet : public MQTTSocket
     EthernetInterface eth;
public:
    MQTTEthernet()
        eth.init();                          // Use DHCP
        eth.connect();
    EthernetInterface& getEth()
        return eth;
    void reconnect()
        eth.connect();
Error: No default constructor exists for class "EthernetInterface" in "MQTT/MQTTEthernet.h", Line: 15, Col: 6
Thank you for your help
Philipp
Can you please edit this to use <<code>> and <</code>> so that we can tell which bits are comments and which bits are the code.
posted by Andy A 29 Sep 2016
Are you running this against mbed 2.0 or mbed OS 5? mbed OS 5 interface changed, the MQTT project only works against mbed 2.0...
