9 years, 2 months ago.
keypad.h
I have found multiple codes for using a 12 button keypad. All of them have "#include "Keypad.h"" or something similar (keypad.h, keypad3x4.h), but I get an error code regardless of which one I use. The error code states that there is no such file or directory. Is there a keypad file that works?
hi Dustin, I came across this question, but I can't tell if it is a question for the RA8875 driver I created. If it is, then you might update your library. Some of the earlier work for a keypad had a separate header file, but the current version does not require that.
