10 years, 11 months ago.
Compare Integer #CAN #Format
I'm writing a program, which reads CAN-data (ID,DLC,DATA) from a text document and send it as a CAN message to the Transceiver. It works fine. I just need a bit help to compare my ID's.
I Have to know if the ID is a Stadard-Frame (11-bit) or an Extended-Frame Format (29-bit).
There are Integer like this (Extended): 1B000012x, 1BFC0C11x, 1BFC0C21x.
And Integer like that (Standard): 86, B4, 121.
Only if I know which Format the ID is I can decide which "send-function" I use. So I need and IF-condition.
Now the question: What is the best way to check if it is a Stadard or Extended Format? You have a hint for me?
Many Thanks Marv
So extended IDs all end in an x?
If so and assuming you have the ID in a standard c string format then
int idLength = strlen(IDString);
if ( *(IDString+idLength-1) == 'x' ) {
message.format = CANExtended;
message.id = strtol(IDString,IDString+idLength-1,16);
} else {
message.format = CANStandard;
message.id = strtol(IDString,null,16);
should set the ID and format for an mbed standard CANMessage data structure.
