9 years, 6 months ago.
Teensy 3.5/3.6
How long does it take to see the compatibility with the two new boards? Thanks
The PJRC Teensy 3.1 operates at CPU frequency of 96MHz. The powerful ARM-M4 Freescale MK20DX256VLH7 MCU has 256 kB of flash memory, 64 kB of RAM memory. This platform is …
There is no compatibility as these use a different MCU. A new Mbed library would have to written for this target. Not impossible but it would be a lot of work.
Whilst the 3.1 is a great 'small' footprint board currently the fastest in its size class on Mbed @ 96MHz, 28pin layout, it does have low power and other limitations due to the circuit design and PCB layout. It would appear that the 3.5/3.6 will be much the same just a larger more powerful version.
For a more powerful Mbed currently supported, these may be a better consideration;
https://developer.mbed.org/platforms/ST-Nucleo-F746ZG/
https://developer.mbed.org/platforms/ST-Nucleo-F429ZI/
ST are supporting these very well on Mbed now, they also have some very good low power capable boards.
https://developer.mbed.org/platforms/ST-Nucleo-L476RG/
