9 years, 4 months ago.
Nucleo w/ DHT22 temperature/humidity sensor
Hi, I'm trying to use the DHT22 temperature and humidity sensor with the Nucleo-L152RE. The wiring seems straight forward, I have a pull up resistor on the data pin.
But I'm only getting 0 values from the ReadHumidity() function call. The library I'm using is
https://developer.mbed.org/users/Wimpie/code/DHT/file/9b5b3200688f/DHT.h
#include "MBed_Adafruit_GPS.h"
#include "DHT.h"
Serial * gps_Serial;
Serial pc (SERIAL_TX, SERIAL_RX); //this is the USB serial output
DHT mydht(PB_4, DHT22); //pin 5 on nucleo
//Serial pc (USBTX, USBRX);
    pc.baud(9600); //sets virtual COM serial communication to high rate; this is to allow more time to be spent on GPS retrieval
    char c;
    Timer refresh_Timer;
    const int refresh_Time = 2000;
    wait(1);
    refresh_Timer.start();  //starts the clock on the timer
    while(true){
        if (refresh_Timer.read_ms() >= refresh_Time) {
            refresh_Timer.reset();
            int temperature = mydht.ReadHumidity();
            pc.printf("Satellites: %d\n", temperature);
Affordable and flexible platform to ease prototyping using a STM32L152RET6 microcontroller.
Hi Eric,
Thanks for your question :)
A couple of things:
What value of pull up resistor are you using, id recommend 4.7K to 10k.
Have you tried this in a simple program?
Have you tried a different library? such as found here:
https://developer.mbed.org/cookbook/Grove-temperature--humidity-sensors
Andrea, team mbed
