9 years, 5 months ago.
which nucleo board is compatible with SD card?
I am using LO31k6 for now and it shows me following error? Error: No space in execution regions with .ANY selector matching ccsbcs.NUCLEO_L031K6.o(i.ff_wtoupper). Error: No space in execution regions with .ANY selector matching mbed_board.o(i.mbed_error_printf). Error: No space in execution regions with .ANY selector matching SPI.o(i._ZN4mbed3SPI5writeEi). Error: No space in execution regions with .ANY selector matching mbed_critical.o(i.core_util_critical_section_exit). Error: No space in execution regions with .ANY selector matching SDFileSystem.NUCLEO_L031K6.o(.conststring). Error: No space in execution regions with .ANY selector matching TextLCD.NUCLEO_L031K6.o(.conststring). Error: No space in execution regions with .ANY selector matching main.NUCLEO_L031K6.o(.conststring). Error: No space in execution regions with .ANY selector matching stm32l0xx_hal_rtc.o(i.HAL_RTC_GetDate). Error: No space in execution regions with .ANY selector matching ff.NUCLEO_L031K6.o(i._Z11sync_windowP5FATFS).
Affordable and flexible platform to ease prototyping using a STM32F042K6T6 microcontroller.
Hello, If you compile for the L073, you will find out that MBED lib + SDCARD lib takes around 50kb of flash. This just does not fit in the L031 and its 32kb of flash.
Which microcontroller with M0 cortex do you suggest for me. I am in doubt because previously it didnt work with L152RE too. They are still solving the problem for that. Is there any nucleo board that you have tested with MBED SDCARD. ? Thank you
posted by jayendra mishra 12 Sep 2016
Hello, the mbed SDCARD library use the SPI peripheral, it should work fine on any device with a SPI, provided there is enough program memory space to hold the libraries and the application you want. All STM32 have a SPI, look at the pinout diagram on each platform page in order to locate the SPI pins.
After a quick test I can tell you need about 50k for SDCARD + MBED libraries, so your NUCLEO-L152RE should work fine with its 512 KB of Flash. Could you please explain what is wrong with it?
The STM32L152 is has a cortexM3 core. If you really want a cortex M0 or M0+, I recommand one of the following (in no particular order) :
Of course if you want to use other libraries, the 64k device may fill-up quickly too...
posted by Maxime TEISSIER 13 Sep 2016
