9 years, 8 months ago.
Where download ST-LINK V2-1 driver for Windows 7 64bit?
I have NUCLEO-F410RB. But,I download ST-LINK V2-1 driver is don't work. The driver from http://www.st.com/content/st_com/en/products/embedded-software/development-tool-software/stsw-link009.html. It reminds me that "the version of this file is not compatible with the version of windows you're running.check your computers system to see whether you need an X86(32-bit) or X64 (64bit) version of the program.and then contact the software publisher you thin the item is damaged during the seperation "
Could you help me, what should I do?
My E-mail: 1444197961@qq.com Thank you~
Did you try to run the co-installer ?
Run dpinst_amd64.exe installer if you have a 64 bit platform.
Run the dpinst_x86.exe installer for a 32 bit platform.
If you allow Windows to automatically search the folders (without the installer package) then Windows will search the first sub-folder (x86 = 32 bit) -> will fail on a 64 bit CPU and report the message in your post.
Using the co-installer, Windows will be forced to use only the correct sub-folder. Please test again and post your results.
