10 years, 11 months ago.
Output is zero?
Hello, Sir. Thanks to your project I was kind of able to read data from TSL2561 through mbed. However, as default, it reads zero all the time. I was able to get reasonable value only when I activate some DEBUG_PRINTLNXY() function in some places. This printing function itself should not be related to communication of I2C but somehow there is such difference. Can you guess why this is happening? And does your main.cpp of this project work without any modification? Thank you in advance.
Hi Shu, could you make it work? I get also zero all the time, and even after uncommenting DEBUG_PRINTLNXY, not changes. Thanks
posted by Ousmane Sangare 17 Aug 2015
