9 years, 6 months ago.
Exporting project with the RTOS integrated
How do you export an mbedOS project with the RTOS integrated. I only ever get it without the RTOS. I am currently trying it with mbed OS release from github (https://github.com/ARMmbed/mbed-os). I cannot use the CLI as 1) I would like to have the whole SDK at the same time ,2) I am behind a firewall.
I tried it for the SAMD21G18A (Arduino Zero) and the NUCLEO_F411RE targets. Both result in the similar export builds.
Basically i install the release with (python setup.py install) and then (python project.py -m SAMD21G18A -i gcc_arm -p 0). Similar for the ST Nucleo board. I can get the blinky running with the normal wait but not with Thread.
Looking forward to working with the mbedOS 5
Thank you, Kevin Goveas
Hi Kevin,
First of all, using mbed CLI is just a wrapper around manually cloning mbed OS (and some build scripts). It does contain the full SDK - including all targets and features - when you start a new project through it. The easiest way to start behind a firewall would be to create a new project outside the realms of the corporate network, place all files on a USB drive and then import. You'll have all targets & features present and do not need internet access to build. It's way more versatile than doing an export from online compiler (as that will be single target).
