9 years, 6 months ago.
Update FRDM bootloaders using only Windows 10
Windows 10 will not allow you to drag and drop files to the FRDM boards (with older bootloaders)
Is it possible to replace the Bootloader from Windows 10 with no extra hardware?
As far as I can see, the only methods are: 1. Find a Win7 PC from somewhere. Copy-Paste a replacement OPENSDA file to each FRDM board. 2. Mount a JTAG header and program the OPENSDA chip via an external J-Link debugger.
It would be useful to have a step-by-step guide.
David.
you can try this for drag and drop solution type RUN in your window and regedit go to HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Policies > System Change "EnableLUA" 1 to 0. you may also visit here https://hpetechnicalsupportnumber.com/blog/how-to-fix-hp-error-code-0xc0000225/ because you might have issues while window 10 update
posted by mohana shaw 02 Nov 2018
Malwarebytes Customer Care Support team for instant help related to resolving all kind of general or technical problems occurring in their Malwarebytes account. For more information dial toll-free numbers +1-844-534-8410 (US, CANADA) https://www.malwarebytessupportnumber.com
posted by Lisa Haydon 10 Jan 2019
Our executives would be available to solve any kind of issues while downloading and installation of the Antivirus software. You can always refer the guide to know more information about the software or you can call us at the same time. Antivirus Help Number +1-888-499-5520 (US, CANADA) Or visit- https://www.setup-and-activate.com/ https://www.setup-and-activate.com/about-us/ https://www.setup-and-activate.com/contact-us/ https://www.setup-and-activate.com/avg-support-phone-number/ https://www.setup-and-activate.com/norton-support-phone-number/
posted by Mary Hill 11 Feb 2019
8 years, 3 months ago.
There has been an update for DAPLink and the bootloader. Have a read through this blog. https://os.mbed.com/blog/entry/DAPLink-bootloader-update/
9 years, 3 months ago.
I was able to do this by piecing together information I found. I updated the bootloader on several boards using only Windows 10.
1) Run gpedit.msc as Administrator and enable "Computer Configuration \ Administrative Templates \ Windows Components \ Search \ Do not allow locations on removable drives to be added to libraries."
2) Bring up board in Bootloader mode (hold reset button while plugging in to computer)
3) Copy new bootloader to board.
4) Power cycle board in non-bootloader mode (do not hold the reset button down while plugging the board back in. It should still come up in bootloader mode. If you power cycle in bootloader mode (with reset pressed) the device will not be reprogrammed.) Check the SDA_INFO.HTM file for updated version numbers.
Tony
The reality can't be disregarded that infection are getting more grounded step by step and that is the reason you have to run with the new age Avast Antivirus. We have refreshed it and thinking of the new age innovation. For more information dial toll-free numbers +1-888-499-5520 (US, CANADA)
Or visit- https://avastphonenumber.com/ https://avastphonenumber.com/about-us/ https://avastphonenumber.com/contact-us/ https://avastphonenumber.com/blog/
posted by Mary Hill 10 Jan 2019
