9 years, 7 months ago.
Error: Target "NUCLEO_F207ZG" is not recognized
I created a program with the nrf51 using a 9DOF sensor and an SD card and works like a charm. When porting to ST Nucleo boards, the I2C seems to work on M0+ and M4 NUCLEO boards but the SD access through SPI does not work and behaves the same on both boards.
On an M3 Nucleo STM32F207ZGT6 I am able to compile a limited number of NUCLEO provided examples, but when I used a different exampleother than the NUCLEO examples such as e.g. "Hello World SDFileSystem" get the following message.
But if I compile for the STM32F303 or the STM32L053, it compiles and can access the SD card. On the other hand the NUCLEO_F207ZG is the last in the list of available boards even if I add more NUCLEO boards to the list of available boards.
I have seen several messages in which there were similar errors and they were because the boards were not iupdated in the library or somewhere.
How can I fix this intermittent problem?
STM32 Nucleo-144 development board with STM32F207ZG MCU, supports Arduino, ST Zio and morpho connectivity
Hello, you need to update the mbed library to the latest version. Older version are probably being used in the examples you are mentioning but those did not support the NUCLEO-F207ZG platform.
Thank you , this solution works
posted by seifeddine benomar 14 Mar 2018
