13 years ago.
secure SHT75 connection to application board
It´s possible to connect a SHT75 humidity and temperature sensor to the application board? I think if the components soldered in the board are directly connected to the mbed a comunication error or a damage could occur.
13 years ago.
You may also use it on the I2C bus pins:
Quote:
The sensor cannot be addressed by I2C protocol, however, the sensor can be connected to an I2C bus without interference with other devices connected to the bus. Microcontroller must switch between protocols.
13 years ago.
Why don't you use the not needed digital I/Os of the Servos or ZigBee connection?!
