10 years, 11 months ago.
Unable to load binary with MSD
I have connected the USB cable on SDA USB. And i try to copy the the helloworld binary. Looks like it copied well, but immediately disappears. Again the MBED.HTM appears back. looks like the data is lost. I did try upgrading the interface firmware but the same behavior. Somebody help please, am newbie to mbed and freescale platforms however not new to embedded systems.
What you describe is exactly how it is intended to work. After programming the bin file disapears from the MSD, and instead is programmed in your target. Click the reset button (or power cycle, or send serial break), and your program should run. Try a simple blinking LED program to verify this.
I am also facing same issue.. the chart isn't generating in the streaming section of dashboard. kindly help me.
posted by Harshini Shivashankar 18 May 2016
