9 years, 6 months ago.
when combining 2 of this code why only the 2nd part of the while loop works?
these will be the 2 code i want to combine.
Serial xbee1(PA_9, PA_10);
DigitalOut Relay(PB_0);
const char RelayCommand[3] = { 0xAB, 0x01, 0x99 };
int byteCount = 0;
char byteIn;
while (true) {
byteIn = xbee1.getc();
if (byteCount < 3) { // still looking for the header
if (byteIn == RelayCommand[byteCount]) // data in matches the next byte in the header
byteCount++; // expect the next header byte
else if (byteIn == RelayCommand[0]) // Got the first byte of a header when we didn't expect it
byteCount = 1; // expect the second byte next
else
byteCount = 0; // No idea what's going on. Go back to the start
} else { // got the full header.
if (byteIn == 0x01) {
Relay = 1;
pc.printf("on");
else if (byteIn == 0x00) {
Relay = 0;
pc.printf("off");
byteCount = 0;
and
Ticker PIR_ticker;
Ticker analogue_ticker;
AnalogIn sensor(A0);
DigitalIn alarm(A1, PullUp);
DigitalOut led1(LED1);
volatile float dist;
volatile float ain;
volatile bool newReading = false;
volatile bool PIRAlarm = false;
volatile bool newPIR = false;
bool alarmOn = false;
// read the ultrasound range
void getAnalogue()
ain = sensor.read();
dist = ain*1024*5/1000;
newReading = true;
// read PIR sensor
void getPIR()
PIRAlarm = alarm;
newPIR = true;
// send an ultrasound range message
const unsigned char ultrasonicMsg[4] = { 0xAB, 0x01, 0x89 };
void sendRange(float distance)
// calculate the range byte
int rangeIn2cmUnits = (distance/0.02) + 0.5; // convert to units of 2cm and round to nearest integer.
if (rangeIn2cmUnits < 0) // should never be negative but just in case
rangeIn2cmUnits = 0;
if (rangeIn2cmUnits > 250) // over 5 meters
rangeIn2cmUnits = 251; // use a value of 251 to indicate anything over 5m.
// send the message header
for (int i = 0; i<3; i++)
xbee1.putc(ultrasonicMsg[i]);
// send the range
xbee1.putc((unsigned char)rangeIn2cmUnits);
// send the alarm on/off message
const unsigned char alarmMsg[3] = { 0xAB, 0x01, 0x88 };
void sendAlarm(bool on)
xbee1.putc(alarmMsg[i]);
//send the alarm status
if (on)
xbee1.putc(0x01);
else
xbee1.putc(0x00);
// set/clear the flag indicating that the alarm is in.
alarmOn = on;
// set the LED to match the alarm status
if (on)
led1=1;
else
led1 = 0;
pc.printf("running\n");
// attach the tickers to read the values.
analogue_ticker.attach(&getAnalogue, 2.0);
PIR_ticker.attach(&getPIR, 1.0);
// loop forever
if(newPIR||newReading) { // if there is something to do
if (alarmOn == false) { // if the alarm is currently off
if (PIRAlarm || (dist < 0.4f)) { // if the alarm should be on
sendAlarm(true); // send the alarm on message
} else { // the alarm is currently on
if (!PIRAlarm && (dist > 0.5f)) { // no PIR and range is > 0.5m
sendAlarm(false); // send the alarm off message
// if the alarm is on and we have a new range measurment
if (alarmOn && newReading) {
sendRange(dist); // send the range message
pc.printf("ain = %.4f, dist = %.4f\r\n", ain, dist); // output debug text
// clear the new reading flags.
newPIR = false;
newReading = false;
getc() will block until it gets data so the loop will sit there waiting for data to arrive from the radio.
If the only thing the while loop is doing is reading data then that's not a problem. If it needs to also do something else then it is a problem.
Fortunately there is a simple solution, make all of the data reception code conditional on there being data to read.
if (xbee.readable()) {
byteIn = xbee1.getc());
all the other code to do with reading the received data
Also when you combined the two pieces of code byteIn and byteCount seems to have become globals for no good reason and this function which is never called seems to have magically appeared.
void getSTATE()
so when i combine it only line 127-144 works. why is that and how to make the whole while loop work?
#include "mbed.h" Ticker PIR_ticker; Ticker analogue_ticker; AnalogIn sensor(A0); DigitalIn alarm(A1, PullUp); DigitalOut led1(LED1); DigitalOut Relay(PB_0); Serial pc(SERIAL_TX, SERIAL_RX); Serial xbee1(PA_9, PA_10); int byteCount = 0; char byteIn; volatile float dist; volatile float ain; volatile bool newReading = false; volatile bool PIRAlarm = false; volatile bool newPIR = false; bool alarmOn = false; // read the ultrasound range void getAnalogue() { ain = sensor.read(); dist = ain*1024*5/1000; newReading = true; } // read PIR sensor void getPIR() { PIRAlarm = alarm; newPIR = true; } // send an ultrasound range message const unsigned char ultrasonicMsg[4] = { 0xAB, 0x01, 0x89 }; void sendRange(float distance) { // calculate the range byte int rangeIn2cmUnits = (distance/0.02) + 0.5; // convert to units of 2cm and round to nearest integer. if (rangeIn2cmUnits < 0) // should never be negative but just in case rangeIn2cmUnits = 0; if (rangeIn2cmUnits > 250) // over 5 meters rangeIn2cmUnits = 251; // use a value of 251 to indicate anything over 5m. // send the message header for (int i = 0; i<3; i++) xbee1.putc(ultrasonicMsg[i]); // send the range xbee1.putc((unsigned char)rangeIn2cmUnits); } // send the alarm on/off message const unsigned char alarmMsg[3] = { 0xAB, 0x01, 0x88 }; void sendAlarm(bool on) { // send the message header for (int i = 0; i<3; i++) xbee1.putc(alarmMsg[i]); //send the alarm status if (on) xbee1.putc(0x01); else xbee1.putc(0x00); // set/clear the flag indicating that the alarm is in. alarmOn = on; // set the LED to match the alarm status if (on) led1=1; else led1 = 0; } // read STATE from xbee const char RelayCommand[3] = { 0xAB, 0x01, 0x99 }; void getSTATE() { byteIn = xbee1.getc(); } int main() { pc.printf("running\n"); // attach the tickers to read the values. analogue_ticker.attach(&getAnalogue, 2.0); PIR_ticker.attach(&getPIR, 1.0); // loop forever while(1) { if(newPIR||newReading) { // if there is something to do if (alarmOn == false) { // if the alarm is currently off if (PIRAlarm || (dist < 0.4f)) { // if the alarm should be on sendAlarm(true); // send the alarm on message } } else { // the alarm is currently on if (!PIRAlarm && (dist > 0.5f)) { // no PIR and range is > 0.5m sendAlarm(false); // send the alarm off message } } // if the alarm is on and we have a new range measurment if (alarmOn && newReading) { sendRange(dist); // send the range message pc.printf("ain = %.4f, dist = %.4f\r\n", ain, dist); // output debug text } // clear the new reading flags. newPIR = false; newReading = false; } byteIn = xbee1.getc(); if (byteCount < 3) { // still looking for the header if (byteIn == RelayCommand[byteCount]) // data in matches the next byte in the header byteCount++; // expect the next header byte else if (byteIn == RelayCommand[0]) // Got the first byte of a header when we didn't expect it byteCount = 1; // expect the second byte next else byteCount = 0; // No idea what's going on. Go back to the start } else { // got the full header. if (byteIn == 0x01) { Relay = 1; pc.printf("on"); } else if (byteIn == 0x00) { Relay = 0; pc.printf("off"); } byteCount = 0; } } }
