11 years, 1 month ago.
Where can I find ST Link Driver for linux (fedora)?
https://github.com/texane/stlink
STLink setup isnt too bad, but good luck with the whole arm-none-eabi-gcc-cs setup and compiling code. I literally just gave up on trying to use arm and fedora. Back to windows
Remember to add ATTRS{idVendor}=="0483", ATTRS{idProduct}=="3748", MODE="0666" to /etc/udev/rules.d/stlinkv2.rules
hi, I install stlink, and can use st-util to detect devices as below.
2016-03-07T21:48:52 INFO src/stlink-common.c: Loading device parameters....
2016-03-07T21:48:52 INFO src/stlink-common.c: Device connected is: F4 device (Dynamic Efficency), id 0x10006433
2016-03-07T21:48:52 INFO src/stlink-common.c: SRAM size: 0x18000 bytes (96 KiB), Flash: 0x80000 bytes (512 KiB) in pages of 16384 bytes
2016-03-07T21:48:52 INFO gdbserver/gdb-server.c: Chip ID is 00000433, Core ID is 2ba01477.
2016-03-07T21:48:52 INFO gdbserver/gdb-server.c: Target voltage is 3261 mV.
2016-03-07T21:48:52 INFO gdbserver/gdb-server.c: Listening at *:4242...
but I still can't find /dev/ttyUSB0. And I can't use USB serial to debug my program. But in Windows, if I install stlink driver, I can use USB VPC(printf) to debug my program.
Do I miss something others???
posted by 07 Mar 2016
