12 years, 12 months ago.
Is CAN communication set up on the mbed?
What all do I need to do to communicate to another micro via CAN interface? The other micro already has CAN set up and I want to be able to send and receive CAN message id(s) to/from the other micro. I have the CAN transceiver with needed components and circuitry complete. I am wired to mbed dip pins 29 & 30 (CAN2). Do I need to set up the clock speed and registers? I am planning on using HS CAN (500Kb/s bit rate). I want to use 11-bit can id(s). Any and all help is greatly appreciated. Please help.
12 years, 11 months ago.
Hi Chad, You might have found the answer already. Between the mbed and the actual CAN network, you need a transceiver chip. This is [often] an 8-pin part. There are several schematics scattered about the site, on this page you'll find one about half-way down.
For the software to make it go, here's the sample from the Handbook. I don't recall the default bit-rate by the mbed library, but a simple call like "can1.frequency(500000);" should work.
The CAN driver supports both 11 and 29-bit identifiers. Follow the samples and dig into the APIs in the Handbook and you'll see.
So, my recommendation would be to first experiment with the mbed and 2 channels of CAN (if you have the LPC17868). Wire them thru the transceivers to each other. Then you can experiment in a more controlled environment than with the other device you mention. Once you learn to send and receive basic messages, then you can figure out the 11 vs. 29-bit format. After that you're probably ready to tap in to the other network.
