9 years, 9 months ago.
Hard Fault Error at NUCLEO L073RZ
Hello, I'm using NUCLEO L073RZ board. But, the binary file, which is created by online compiler, is not working. So, I'm test using Keil compiler and exported mbed code (Example code : Display a message on PC using UART). Before this code started, the board is in Hard-Fault Handler. Callee of Hard-Fault Handler is time_irq_handler. Other example codes in online compiler have the same problem. What is the problem?
Affordable and flexible platform to ease prototyping using a STM32L073RZT6 microcontroller.
