9 years, 9 months ago.
No messages on mDoT Debug Port
I have tried two sample apps - mDot_helloworld and mDot_Lora_connect_example. On the helloworld - i can observe the LED blinking on the UDK. In case of LoraConnect Example - I can receive data on the mLinux Conduit. In both cases - I do not see any debug messages on the serial consoles - not on DB9 or the serial console.
9 years, 8 months ago.
Hello, I am experiencing the exact same problem.
I am using the micro developer board. I am using a PC with windows and the serial port is set to 9600-N-1-8.
Strangely, when i load the AT command sample code, it runs smoothly and I can send AT commands via serial port.
Any suggestions ?
Thank you very much! Fede
The debug port is set to 9600-N-1-8 by default. Did you check your baud rate settings? Als what operating system are you connecting the UDK to?
Any suggestions ?
posted by federico villalpando 25 Jul 2016
