9 years, 9 months ago.
When using multiple Ticker instances, can we not mix attach and attach_us ?
I have five Ticker instances, all with attach (milliseconds) . I need finer resolution on one of them, so I decided to use attach_us and now they all fail....
The ONLY thing I'm doing inside the attach_us routine is updating a volatile counter that is referenced outside of the ISR.
Thoughts?
All the ticker attach function does is call attach_us with the time multiplied by 1,000,000
Other than the time taken to do a floating point multiply attach and attach_us are identical.
void attach(void (*fptr)(void), float t) {
attach_us(fptr, t * 1000000.0f);
template<typename T>
void attach(T* tptr, void (T::*mptr)(void), float t) {
attach_us(tptr, mptr, t * 1000000.0f);
How many microseconds do you use?
And second question is: Why do you need that? (Since it does not work you probably need to search for a plan B ;) ).
posted by Erik - 31 May 2016I'm running PID control and path planning for two DC servo motors. I was planning on running the loop at 100khz (10us) ... the other processes are all 20-100ms.
posted by Michael Ball 01 Jun 2016I can't answer anymore since you marked it as solved, but your issue is simply that the sum of the ARM interrupt architecture + mbed library overhead + your code is more than 10us. But why are you updating that volatile counter every 10us?
posted by Erik - 01 Jun 2016Thank you for your feedback Erik, and for making me thing deeper/differently on this problem.
The primary process - the actual motion control - is free wheeling at whatever speed it can loop in main. It checks to counter at various times to synchronize certain sub processes. A 100khz counter is about the resolution I was hoping for. The CPU runs at 120Mhz, so this should be a trivial counter speed. I've put some code in to toggle unused GPIO pins during the motion control process, so I can visually see what's going on.
posted by Michael Ball 01 Jun 2016Wouldn't just reading a Timer (or us_ticker_read()) be easier? Then you got it in 32-bit with 1000kHz resolution, and except the reading part no overhead (especially if you use us_ticker_read()).
posted by Erik - 01 Jun 2016Truthfully, I was unaware of us_ticker_read(), and just re-using what I "know" to work. LOL I'll try it. THX.
For the record: The problem was user error... I had a errant "printf" statement buried in code that was intended for debug. It messed with the timer interrupt... removed it,and we are happy again.
Appreciated Erik.
