11 years ago.
SI4703
I'm trying to control the SI4703 radio chip with the mbed lpc 1768 and I2C bus. I can't figure out how to power up the SI4703.
Anyone for help?
Here are the links to the datasheet with registers (page 23)
https://www.sparkfun.com/datasheets/BreakoutBoards/Si4702-03-C19-1.pdf
and the AN230 sheet with a description how to power it up (page 12)
http://www.silabs.com/Support%20Documents/TechnicalDocs/AN230.pdf
I don't know how to handle the registers.
11 years ago.
Try here, the programming should be very similar.
https://developer.mbed.org/users/kpatel70/notebook/si4735-digital-fm-radio-receiver-with-rdsrbds/
Thanks for your answer. Still got the problem of powering up the chip via I2C bus.
Is there a possibility to set SDA (pin 9/ pin 28) manually to low ? To power it up I need SDA on a low level and reset on a high level. In the example for the arduino uno, first they initialise pin A4 as a digital output, then they use it for SDA. Here's the example code:
void Si4703_Breakout::si4703_init() { pinMode(_resetPin, OUTPUT); pinMode(_sdioPin, OUTPUT); SDIO is connected to A4 for I2C digitalWrite(_sdioPin, LOW); A low SDIO indicates a 2-wire interface digitalWrite(_resetPin, LOW); Put Si4703 into reset delay(1); Some delays while we allow pins to settle digitalWrite(_resetPin, HIGH); Bring Si4703 out of reset with SDIO set to low and SEN pulled high with on-board resistor delay(1); Allow Si4703 to come out of reset
Wire.begin(); Now that the unit is reset and I2C inteface mode, we need to begin I2C
posted by 10 Apr 2015
