9 years, 10 months ago.
Latest mbed-rtos breaks Ethernet on K64F
FYI,
Version 111 of mbed-rtos works, 114 is broken.
...kevin
can you be more specific, breaks how ? compilation error ? run time error ? How to reproduce it?
Update: I had a look, EthernetInterface was not updated, thus lwip-sys did not reflect the size of mutex for new kernel (was changed in RTX). I tested this with TCP hello world. Previously field, with an update, passes.
posted by 10 May 2016what is the revision you are testing with? get the latest EthernetInterface, should get dhcp address. (revision 53 fixes it)
posted by 10 May 2016That's correct, it should be now available : https://developer.mbed.org/users/mbed_official/code/EthernetInterface/
posted by 10 May 2016Perfect Martin!!
DCHP works, pinging works, NTP client works, TFTP Server works and SD File access works!!
All is right with the world. Thanks Martin
