9 years, 10 months ago.
terminal setting for tera term
what terminal setting should i change in my tera term so it could display what i want after connected it with the serial port driver.
The mbed default settings are 9600 baud, 8 bits, no parity, 1 stop bit, no flow control.
Shouldn't matter much. Mine is set to: ID VT100, Coding UTF-8 New line recieve Auto, transmit CR Local echo off.
About the only one of those that should make any difference is the new line settings, if they don't match your program then new lines will look wrong. There shouldn't be any settings there that would stop things from displaying.
posted by 03 May 2016
because has for right now it didn't display anything on my tera term
posted by kevan foong 03 May 2016
