9 years, 10 months ago.
array size is padded to 8 byte?!?!?
Something weird I stumbled upon today:
typedef struct { uint8_t A[7]; uint32_t B; } strct;
Expecting sizeof(strct) to be 7+4 = 11 bytes, but instead I get 12. Looking at the memory layout, it looks like a byte is padded between A and B values.
Explanation ?
This is normal for C compilers, also some CPU require int on sizeof(int) boundaries. For several compilers there are pragma statements change this. Look for "#pragma pack" of the ARM compiler.
