9 years, 10 months ago.
How to know wizwiki W7500P?(about adrr)
stack base=? stack limit=? heap base=? heap limit=? read from:http://www.nxp.com/documents/data_sheet/LPC11U3X.pdf I can't select about addr.
WIZwiki-W7500P is a SoC platform board based on the W7500P chip = ARM Cortex-M0 that integrates 128KB Flash and hardwired TCP/IP core and MacPhy. If you use WIZwiki-W7500 board, you …
