9 years, 11 months ago.
How to use "printf" by serial on LPC4088DM working with emWin
How to show the message on my Terminal on LPC4088DM working with emWin? For example, I want to press a button and then printf("Hello World!") on my Terminal? I use "pc.printf" , but there just garbled text.
Do you have the correct port settings? The mbed default is 9600 baud, 8 bits, 1 stop bit, no parity. Unless you change things in your program you need to set your terminal to those settings.
If you are using the printf method in the RtosLog class, then the baud rate will be 115200. EA uses the RtosLog in some of their examples,'
