9 years, 11 months ago. This question has been closed. Reason: Unclear question
test
// Calculator: Addition and Subtraction
// Joystick Up: + ; Joystick Down - (Operator selection)
// Joystick Left: count value up (+1); Joystick Right: count value down (-1)
// Joystick Center: Calculate
// Joystick Left or Joystick Right: start at input of value 1 again
#include "C12832_lcd.h"
InterruptIn iiUp(p15);
DigitalIn diUp(p15);
InterruptIn iiDown(p12);
DigitalIn diDown(p12);
InterruptIn iiCenter(p14);
DigitalIn diCenter(p14);
InterruptIn iiLeft(p13);
DigitalIn diLeft(p13);
InterruptIn iiRight(p16);
DigitalIn diRight(p16);
uint8_t step = 0;
char calcOp = '+';
bool updateLcd = true;
int value1, value2, result;
// prototypes
// functions
uint8_t debounce(DigitalIn myIn)
#define LEVEL_CHECKS 8
#define MAX_LOOPS 30 // stoppt das Überprüfen des Prellen nach max. MAX_LOOPS Durchläufen
unsigned char port_buffer;
unsigned char debounceCounter = 0;
uint8_t loopCounter = 0;
do
port_buffer = myIn;
wait_us(100);
loopCounter++;
if(myIn == port_buffer)
debounceCounter++; // mindestens 'LEVEL_CHECKS' Abtastungen in Folge: gleicher Pegel
else
while ((debounceCounter <= LEVEL_CHECKS) && (loopCounter <= MAX_LOOPS));
return loopCounter;
// ISR
// main program
C12832_LCD lcd;
lcd.cls();
lcd.locate(0,0);
lcd.printf("5ABELI: Calulator");
if (updateLcd) {
updateLcd = false;
switch (step) {
case 0:
lcd.locate(0, 20);
lcd.printf("%d ", value1);
break;
case 1:
break;
default: break;
- include "mbed.h"
- include "C12832_lcd.h"
InterruptIn iiUp(p15); DigitalIn diUp(p15); InterruptIn iiDown(p12); DigitalIn diDown(p12); InterruptIn iiCenter(p14); DigitalIn diCenter(p14); InterruptIn iiLeft(p13); DigitalIn diLeft(p13); InterruptIn iiRight(p16); DigitalIn diRight(p16); unint8_t step = 0; char calcOp = '+'; bool updateLcd = true; int value1, value2, result;
uint8_t debounce(DigitalIn myIn) {
- define LEVEL_CHECKS 8
- define MAX_LOOPS 30 unsigned char port_buffer; unsigned char debounceCounter = 0; uint8_t loopCounter = 0;
do { port_buffer = myIn; wait_us(100); loopCounter++; if(myIn == port_buffer) debounceCounter++; mindestens 'LEVEL_CHECKS' Abtastungen in Folge: gleicher Pegel else debounceCounter = 0; } while ((debounceCounter <= LEVEL_CHECKS) && (loopCounter <= MAX_LOOPS)); return loopCounter; }
void Plus() {
debounce(dsUp);
calcOp = '+';
step = 1;
updateLcd = true;
void Minus() {
debounce(diDown);
calcOp = '-';
step = 1;
updateLcd = true;
void countUp() {
debounce(diLeft);
if (step == 0)
value1++;
if (step == 1)
value2++;
step = 2;
updateLcd = true;
void countDown() {
debounce(diRight);
if (step == 0)
value1;
if (step == 1)
value2;
step = 2;
updateLcd = true;
void Calculate() {
debounce(diCenter);
if (calcOp = '+')
result = value1 + value2;
if (calcOp = '-')
result = value1 - value2;
step = 3;
updateLcd = true;
int main() { C12832_LCD lcd; lcd.cls(); lcd.locate(0, 0); lcd.printf("4CHEL Calulator");
iiJsUp.rise(&Plus); iiJsDown.rise(&Minus); iiJsLeft.rise(&countUp); iiJsRight.rise(&countDown); iiJsCenter.rise(&Calculate); while(1) { if (updateLcd) { updateLcd = false; switch (step) { case 0: lcd.locate(0, 20); lcd.printf("%d ", value1); break; case 1: lcd.locate(0, 20); lcd.printf("%d %c ", value1, calcOp); break; case 2: lcd.locate(0, 20); lcd.printf("%d %c %d", value1, calcOp, value2); break; case 3: lcd.locate(0, 20); lcd.printf("%d %c %d = %d", value1, calcOp, value2, result); step = 0; value1 = 0; value2 = 0; result = 0; break; default: break; } } } }
When posting code please use
<<code>>tags so that the formatting is correct e.g.See the editing tips link for more details.
posted by Andy A 15 Apr 2016
