9 years, 11 months ago.
LoRaWAN frequency tables
The MDOT library provides two LoRaWAN band plans enumerated as FB_915 (USA with 8 sub-bands of 8 channels each) and FB_868 (EU). I would like to enter a new table and/or modify the frequencies in the FB_915 table for some RF experiments we are doing in our EMC lab which is a shielded environment. There are no FCC or other regulatory issues to consider in this case.
Is there a quick way I can do this? The MDOT library header file does not expose the actual frequency tables. Is the code for this library available?
Any help will be rewarded by good khama and happiness.
The MTDOT-BOX/EVB provides Long Range RF LoRa end-point functionality without the need for heavy configuration or embedded design skills.
