10 years ago.
SPI_CS is not working
Hello?
I'm using NUCLEO-F446RE borad.
If I don't use SPI_CS like,
SPI device(SPI_MOSI, SPI_MISO, SPI_SCK);
it's working well but, if i use SPI_CS like,
SPI device(SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS);
SPI is not working.
Please teach me how to use SPI_CS pin.
Thank you. Tony Kwon
10 years ago.
it should work with and without passing SPI_CS. Which pin are you using for SPI_CS that is failing ?
I'm using PA_15 for SPI_CS pin. And I modified PinNames.h as following,,
... I2C_SDA = PB_9, SPI_MOSI = PA_7, SPI_MISO = PA_6, SPI_SCK = PA_5, SPI_CS = PA_15, /PB_6, PWM_OUT = PB_3, ...
posted by 28 Mar 2016Tony - try to toggle the PA_15 pin (you could use the simple BLINKY LED code). Does that toggle the PA_15 on your Nucleo board ok ?
Hi Tony. Fully understand the hardware CS requirement and the selected PA_15 (CS) pin is the correct choice for your MISO and MOSI pins. The simple test is to only confirm that the PA_15 is functional. From the datasheets, the PA_15 is the hardware SPI CS pin for this SPI port.
