10 years ago.
Transfer data via ethernet LPC1768
Hello, I am on a project where when the LPC1768 received an order via ethernet, I then read data from an accelerometer via I2C and then send back these data via ethernet. The I2C part is OK, but and don't know how to program a server on the LPC1768, I'm searching examples. I think I will use UDP to send data to the client because HTML is too heavy. Thanks
Michel
10 years ago.
You probably want to use TCP not UDP.
UDP is for uni-directional broadcasts with no checking if the data got there or not. TCP is a bi-directional point to point link where the network layer handles acknowledges and re-transmissions.
There is an example server here: https:developer.mbed.org/handbook/Socket
