9 years, 11 months ago.
Trying to build STM32F411RE-nucleo-gcc target with yotta - error ?
I'm just getting started with MBED. I'm trying to build the example program for an STM32F411 Nucleo board this is the output of yotta target:
I basically have two questions: 1. Why does yotta prefer to use board targets as opposed to chip targets ? 2. Why do I get the following error ?
yotta target output
(workspace) C:\Proj\temp\blinky_rev2>yotta target
stm32f411re-nucleo-gcc 0.1.1
mbed-gcc 0.1.4
After issuing yotta build, i get the following error
yotta build output
(workspace) C:\Proj\temp\blinky_rev2> yotta build
info: generate for target: stm32f411re-nucleo-gcc 0.1.1 at C:\Proj\temp\blinky_r
ev2\yotta_targets\stm32f411re-nucleo-gcc
warning: subdirectory "test" of blinky-rev2 0.0.0 at C:\Proj\temp\blinky_rev2 wa
s ignored because it doesn't appear to contain any source files
GCC version is: 4.9.3
CMake Warning at C:/Proj/temp/blinky_rev2/yotta_modules/uvisor-lib/source/CMakeL
ists.txt:60 (message):
           * WARNING (uvisor-lib): unsupported platform; your code will still  *
           *                       work but no security feature is provided;   *
           *                       UVISOR_DISABLED is set by default           *
suppressing warnings from mbed-hal-st-stm32cubef4
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Proj/temp/blinky_rev2/build/stm32f411re-
nucleo-gcc
[1/149] Building CXX object ym/uvisor-...Files/uvisor-lib.dir/unsupported.cpp.o
FAILED: C:\yotta\gcc\bin\arm-none-eabi-g++.exe  -DYOTTA_MODULE_NAME=uvisor-lib -
Igenerated/include -IC:/Proj/temp/blinky_rev2 -IC:/Proj/temp/blinky_rev2/yotta_m
odules/mbed-drivers -IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal-st-stm32cu
bef4 -IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal -IC:/Proj/temp/blinky_rev
2/yotta_modules/cmsis-core -IC:/Proj/temp/blinky_rev2/yotta_modules/ualloc -IC:/
Proj/temp/blinky_rev2/yotta_modules/minar -IC:/Proj/temp/blinky_rev2/yotta_modul
es/core-util -IC:/Proj/temp/blinky_rev2/yotta_modules/compiler-polyfill -IC:/Pro
j/temp/blinky_rev2/yotta_modules/greentea-client -IC:/Proj/temp/blinky_rev2/yott
a_modules/mbed-hal-st -IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal-st-stm32
f4 -IC:/Proj/temp/blinky_rev2/yotta_modules/uvisor-lib -IC:/Proj/temp/blinky_rev
2/yotta_modules/cmsis-core-st -IC:/Proj/temp/blinky_rev2/yotta_modules/cmsis-cor
e-stm32f4 -IC:/Proj/temp/blinky_rev2/yotta_modules/dlmalloc -IC:/Proj/temp/blink
y_rev2/yotta_modules/minar-platform -IC:/Proj/temp/blinky_rev2/yotta_modules/min
ar-platform-mbed -IC:/Proj/temp/blinky_rev2/yotta_modules/cmsis-core/cmsis-core
-IC:/Proj/temp/blinky_rev2/yotta_modules/cmsis-core-stm32f4/cmsis-core-stm32f4 -
IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal-st-stm32f4/mbed-hal-st-stm32f4
-IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal-st-stm32cubef4/mbed-hal-st-stm
32cubef4 -IC:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal/mbed-hal -IC:/Proj/te
mp/blinky_rev2/yotta_modules/mbed-drivers/mbed -fno-exceptions -fno-unwind-table
s -ffunction-sections -fdata-sections -Wall -Wextra -fno-rtti -fno-threadsafe-st
atics -mcpu=cortex-m4 -mthumb -D__thumb2__ -Os -g -gdwarf-3 -DNDEBUG   -DTOOLCHA
IN_GCC -DTOOLCHAIN_GCC_ARM -DMBED_OPERATORS -DTARGET_STM32F411RE_NUCLEO -DTARGET
_STM32F411RE -DTARGET_STM32F4 -DTOOLCHAIN_GCC -DTOOLCHAIN_GCC_ARM -include "C:/P
roj/temp/blinky_rev2/build/stm32f411re-nucleo-gcc/yotta_config.h" -MMD -MT ym/uv
isor-lib/source/CMakeFiles/uvisor-lib.dir/unsupported.cpp.o -MF ym/uvisor-lib/so
urce/CMakeFiles/uvisor-lib.dir/unsupported.cpp.o.d -o ym/uvisor-lib/source/CMake
Files/uvisor-lib.dir/unsupported.cpp.o -c C:/Proj/temp/blinky_rev2/yotta_modules
/uvisor-lib/source/unsupported.cpp
In file included from C:/Proj/temp/blinky_rev2/yotta_modules/cmsis-core-stm32f4/
cmsis-core-stm32f4/cmsis.h:35:0,
                 from C:/Proj/temp/blinky_rev2/yotta_modules/cmsis-core/cmsis-co
re/cmsis_nvic.h:35,
                 from C:/Proj/temp/blinky_rev2/yotta_modules/uvisor-lib/uvisor-l
ib/uvisor-lib.h:23,
                 from C:/Proj/temp/blinky_rev2/yotta_modules/uvisor-lib/source/u
nsupported.cpp:17:
C:/Proj/temp/blinky_rev2/yotta_modules/cmsis-core-stm32f4/cmsis-core-stm32f4/stm
32f4xx.h:154:3: error: #error "Please select first the target STM32F4xx device u
sed in your application (in stm32f4xx.h file)"
  #error "Please select first the target STM32F4xx device used in your applicati
cmsis-core-stm32f4/stm32f4xx.h:213:0,
cmsis-core-stm32f4/cmsis.h:35,
re/cmsis_nvic.h:35,
ib/uvisor-lib.h:23,
nsupported.cpp:17:
C:/Proj/temp/blinky_rev2/yotta_modules/mbed-hal-st-stm32cubef4/mbed-hal-st-stm32
cubef4/stm32f4xx_hal.h:48:32: fatal error: stm32f4xx_hal_conf.h: No such file or
 directory
 #include "stm32f4xx_hal_conf.h"
compilation terminated.
ninja: build stopped: subcommand failed.
error: command ['ninja'] failed
To answer 1st - for blinky you need a board target - to have LED1 defined, stdio defined.
posted by Martin Kojtal 26 Mar 2016
Please post this on mbed.com forum. I recall there was similar error to this one for the same target.
you need install the arm-none-eabi-gcc compiler: http://yottadocs.mbed.com/
Sorry, my platform is Ubuntu.
posted by Yu Yu 26 Mar 2016
I dont think this is related to the gcc , The errors looks like code specific. CMake shall report if gcc arm is not found?
