11 years ago.
Issue getting the application working
Hi Michael,
I have the u-blox C027 dev board with the LISA module running on the AT&T network in the U.S. I am having difficulty getting the program to send data to my M2X channel. I only need to send simple data and do not require any GPS. I stripped out the GPS code segments and the timer (just want to send a single data point for testing).
When I try to run the application I keep getting an HTTP Error 400 - Bad Request.
Maybe I left out something, not sure. I have my API key and ID included.
Do you have a simplified version of your application without GPS I could try?
Thanks, Tony
11 years ago.
Check that you created the stream, feed, keys correctly. Maybe you can verify the request M2X requests from a PC. Check that the M2X client and server are up-to-date and compatible.
You can enable debugging of the mdm driver ith the following statement. mdm.setDebug(4); enable this for debugging issues
Hope this helps.
