10 years, 1 month ago.
PWM
HI,
does this board support PWM?
Hi Chris,
Looks like that platform does support PWM, but it's not currently shown in the pinout diagram.
According to the source code, the following pins support PWM:
P0_8, P1_13 P0_9, P1_14 P0_10, P1_15 P0_21 P0_22, P1_23 P0_18, P1_24 P0_19, P1_25 P0_1, P1_26 P0_13, P1_0 P0_14, P1_1 P0_15, P1_2
If I listed pins on the same line, there's a chance you might have trouble using both of the pins with differing PWM settings at the same time. This is because they use the same underlying PWM peripheral. I'm honestly not sure and I don't have a board here to test it out. That might not be the case at all, but I just thought I'd mention it in case you observe weird behavior in that situation.
If you want to explore the source code, here's the place where I found this info: https://github.com/mbedmicro/mbed/blob/master/libraries/mbed/targets/hal/TARGET_NXP/TARGET_LPC11UXX/TARGET_LPC11U35_401/PeripheralPins.c#L98
The pins listed in that file for CT32B1 are not usable: That timer is already used for the timer/ticker/wait functions (so you can use it, if you don't need those). If you really want those, and not those belonging to CT32B0, you can switch in the us_ticker_api code the timer used for that.
All others are usable, only different pins belonging to the same timer module will have equal period.
posted by 11 Mar 2016
