9 years, 11 months ago.
Creating a single pulse from clock when using TPM channels KL25Z
I'm working on something right now where I need a 10us pulse to trigger a device. I am using TPM0 and the internal clock which is at 41.94Mhz and the output set to a high pulse. I added a push button set up so when it is pushed there is output on another specified pin. I have had no problem creating a waveform that has a 10us period, but the problem I can't figure out is how I can isolate it and get just one of those pulses? Right now when the button is pushed I get the 100kHz square wave that is at 50% duty cycle, which I specified. Can someone tell me how I can get it to do just one pulse and stop?
You could try this, very basic but should give you a 10uS pulse. Not sure which pins are interruptible on the KL25.
Best not to put a 'wait' in your interrupt callback.
snip
InterruptIn button(PTC1); // switch to ground.
DigitalOut pulse(PTB0);
int IRQ;
void IRQ_callback()
IRQ=1;
button.mode(PullUp);
button.fall(IRQ_callback);
if (IRQ==1) { // Button is pressed
pulse=1;
wait_us(10);
pulse=0;
while(!button){} //add some debounce, wait till button released after pulse has fired
IRQ=0;
