10 years ago.
LPC11U37H boards mbed support
Hi all, in the mbed-src there are sources for LPC11U37H and LPCCAPPUCCINO but there is no LPC11U37H supported board in the platforms so I can't set the mbed online compiler accordingly.
Am I wrong? Is there anything I can do?
10 years ago.
Hi Massimo,
At the moment those boards aren't available in the online compiler.
I did double check that the LPC11U37H_401 and LPCCAPPUCCINO platforms compile offline using the mbed repositoy. They compiled fine with GCC_ARM. I don't have those boards to test, so no guarantees :)
If you're interested in developing for this platform, I recommend going through this guide: https://github.com/mbedmicro/mbed/blob/master/docs/BUILDING.md
That will tell you how to build the mbed library for your platform (just replace references to "LPC1768" or "K64F" with "LPC11U37H_401" or "LPCCAPPUCCINO") and how to export a test to an IDE, which you can then modify with your own code.
Hope that helps!
Brian
Thanks Brian, I think it will help. Do you have any guidelines to port to other boards? After I will complete the port is there any possibility it may be added also to the online compiler? Last but not least I know mbed-dev in GitHub, following the rules to compile it I should obtain the mbed release for LPC11U37H eventually ported also to a different board as that from NXP/Embedded Artists. Am I right?
posted by 02 Mar 2016The porting of boards and getting them added to the online compiler goes through the mbed Enabled process, which you can read about here: https://developer.mbed.org/handbook/mbed-Enabled
If the different board uses the same MCU (ex the LPC11U37H) but just changes the pins, then the port should be fairly easy, you'll just need to modify a few of the PinNames in the port. Feel free to browse some of the other boards in the repository for examples.
