10 years ago.
Access to the target folders of the mbed library
I was wondering if access to the target folders are available for the mbed library as they used to be for the mbed-src. I ask as we are wanting to modify some of the pinouts for a target. I could do this for the mbed-src, but I'm having issues with the code using the mbed-src but the mbed library works fine. I see the target folder on the mbed website; however when I import the library none of those folders are available.
It appears the folder must not have fully been transferred over (it seemed to have taken a long time) as I retried and now it appears to be working.
posted by Casey Quinn 01 Mar 2016
10 years ago.
Take into account that for some reason only known to the gods (and possibly mbed staff, but not sure about that one) they renamed mbed-src to mbed-dev, so for the latest version you require mbed-dev.
Good to know. Thanks for that update.
Since the user experience of mbed-src and mbed-dev is slow and clunky to move around, import and export how would you feel about having a repo for each target that only gets the updates that are relevant to the target. This breaks things a bit but the mbed.bld will obviously still exist. It would mean you still need to set the proper target and also have the *right* library imported. I have mixed feelings about this and wondering how power users would feel. IMO mbed-src (now mbed-dev) is only useful when debugging or bringing up new platforms. Feedback??
posted by Sam Grove 01 Mar 2016
Maybe a separate topic would be good for this :).
In addition to the reasons you use, there is another one: Customizing. For example if you want a different clock setup for your board.
For starters: I definately see the problems you mention. The compiler gets close to crashing when you try to update the mbed-dev lib. Having it smaller/less clunky would definately be useful. I think going target specific would really be handy, not always perfect, but generally a better solution. Maybe manufacturer specific would be an inbetween option, although maybe for large ones, such as an STM, you still got a huge lib.
posted by Erik - 01 Mar 2016
OK - Will start a separate thread about this. Good mention on the customization of clocks and hardware. Would be an interesting to see if getting a decent workflow is possible while tracking upstream changes :)
10 years ago.
You should use mbed-dev instead of mbed-src. It's more updated
Good to know. Thanks.
