10 years ago.
How does mbed and the rtos handle device interrupts through GIC?
I have read the Renesas reference manual, the Arm GIC manual, and several online tutorials on using the interrupt controller, but I can't quite figure out if mbed provides an interrupt handler on the A9 core or if I have to provide one in my code. I want to believe that the rtos has handlers in place for each mode the processor might be in, but I haven't found it yet in the mbed source.
The question: assuming that I set up the GIC in a manner similar to that shown in the C code example in "Using the Arm Generic Interrupt Controller" by Altera (ftp://ftp.altera.com/up/pub/Altera_Material/14.0/Tutorials/Using_GIC.pdf, page 17 and on), how do I tell the rtos or the A9 the address of my interrupt handler routine? Or is the GIC already set up in the rtos, and I just need to enable my specific interrupt?
If you have a simple example for mbed, please post it.
- Just Gary
10 years ago.
Hi Just Gary.
Thank you your comments.
The mbed provides an interrupt handler that is placed in mbed library and mbed-rtos library.
GIC function of GR-PEACH is placed in mbed lib too.
You will be able to find the function, as below.
- Interrupt handler
- mbed-dev/targets/cmsis/TARGET_RENESAS/TARGET_RZ_A1H/TOOLCHAIN_ARM_STD/startup_MBRZA1H.S
- mbed-rtos/rtx/TARGET_CORTEX_A/TOOLCHAIN_ARM/HAL_CA9.c
- GIC
The GIC is set up in Reset Handler.
If you want to register your IRQ handler routine to GIC, please refer to below.
mbed-dev/targets/hal/TARGET_RENESAS/TARGET_RZ_A1H/us_ticker.c : Line60 to 62
InterruptHandlerRegister(US_TICKER_TIMER_IRQn, (void (*)(uint32_t))us_ticker_interrupt); GIC_SetPriority(US_TICKER_TIMER_IRQn, 5); GIC_EnableIRQ(US_TICKER_TIMER_IRQn);
Tomo-san -
Thank you. I had found that source file about the same time that you posted your reply, so I quickly made a test. I then got the interrupt, but it looked like the handler would not return. I tried adding a call to GIC_EndInterrupt(IRQn), but it still didn't return. It turns out that it was returning, only to immediately reenter.
Since I am playing with the MTU2 timer, I finally figured out that I have to clear the TGFA bit in MTU2.TSR_1 before I return from the interrupt handler. The example now works great, but for the sake of completeness, do I ever have to issue a call to GIC_EndInterrupt(IRQn), or does the mbed library do that for me? It looks like the library does that for me, but I just want to make sure.
Thanks again,
- Just Gary
posted by 27 Feb 2016Hi Just Gary.
The mbed library do that for you. ICCEOIR will be written in last of IRQ_Handler.(It's same as calling GIC_EndInterrupt(IRQn))
Regards, Tomo Yamanaka
posted by 01 Mar 201610 years ago.
The mbed RTOS is based upon the open source RTX RTOS which is Cortex M specific. http://www.keil.com/pack/doc/CMSIS/RTOS/html/index.html The A9 is such a different beast, that I doubt the low level context switch would be the same. I looked at FreeRTOS and there are vast differences between M and A.
