10 years, 1 month ago.
Destroy and re-init Ethernet interface
how can I close down the EthernetInterface and start it again?
The following example doesn't work. It crashes when it reaches init() for the second time.
Ethernet crash on reinit
void testEthernet()
EthernetInterface eth;
printf("Initializing...\n");
eth.init(); //Use DHCP
printf("Connecting...\n");
int rc = eth.connect();
if (rc == 0)
printf("\nClient IP Address is %s \n", eth.getIPAddress());
eth.disconnect();
while (1)
testEthernet();
wait(1);
Hi Tobias,
Here's my standard pattern, which is obviously a different pattern that your test scenario. I have a slightly customized version of the EthernetInterface, but if you just ignore those calls, it should work for you. I guess I haven't explicitly tested this in a while, but when I did, you could start with or without the cable, and also plug/unplug while running. Some of the applications that used Ethernet were not so kind - if they were in a state to expect something. Well behaved apps return after a timeout.
if (0 == eth.init()) { //Use DHCP
pc.printf("Name: %s\r\n", nn);
eth.setName(nn);
do {
pc.printf("Connecting to network...\r\n");
if (0 == eth.connect()) {
bool initFlag = true;
linkup = true;
ShowIPAddress(true);
int speed = eth.get_connection_speed();
pc.printf("Connected at %d Mb/s\r\n", speed);
while (eth.is_connected()) {
if (initFlag) {
SyncToNTPServer();
initFlag = false;
wd.Service();
Thread::wait(50);
linkup = false;
pc.printf("lost connection.\r\n");
ShowIPAddress(false);
eth.disconnect();
} else {
pc.printf(" ... failed to connect.\r\n");
} while (1);
} else {
pc.printf(" ... failed to initialize, rebooting...\r\n");
mbed_reset();
Note: I'm using this on the LPC1768, and I see you have one of the other devices.
Hi David, thanks for sharing your code!
But if I understand your snippet correctly, you never call eth.init() a second time. So for example changing the IP Address dynamically also isn't possible with your code, right?
posted by 08 Feb 2016That is correct, I don't call it twice. Under DHCP I believe it will work the renewal as the lease time expires. I hadn't thought about forcing a change in IP. I thought routers retained the MAC and then generally grant the same IP on renewal - but this is a "learned" understanding, not necessarily the standard behavior.
