11 years ago.
Follow-up on "singletest.py: need wait between end of copy to target and serial port initialisation"
Hi again. I'm now using a merge of Przemek Wirkus's [thanks Przemek!] push request from here:
https://github.com/mbedmicro/mbed/pull/986
...and it has definitely improved things as tests do now download and run. However, it's not completely reliable. For instance, running test MBED_A1 five times gives me:
TargetTest::LPC1768::GCC_ARM::MBED_A1::Basic [TIMEOUT] in 20.48 of 10 sec TargetTest::LPC1768::GCC_ARM::MBED_A1::Basic [TIMEOUT] in 20.49 of 10 sec TargetTest::LPC1768::GCC_ARM::MBED_A1::Basic [OK] in 1.36 of 20 sec TargetTest::LPC1768::GCC_ARM::MBED_A1::Basic [OK] in 1.34 of 20 sec TargetTest::LPC1768::GCC_ARM::MBED_A1::Basic [TIMEOUT] in 20.47 of 10 sec
In general I get a timeout about 1/3 of the time. Running with -v and looking at a fail case, it says:
Executing 'python host_test.py -d D: -f "C:\projects\mbed\build\test\LPC1768\GCC_ARM\MBED_A1\basic.bin" -p COM31 -t 10 -C 1.5 -m LPC1768'
Test::Output::Start
MBED: Instrumentation: "COM31" and disk: "D:"
HOST: Copy image onto target...
HOST: Initialize serial port...
....port ready!
HOST: Reset target...
HOST: Unknown property:
HTest::Output::Finish
The first Unknown propery: is sometimes followed by { or {{timeout;2. I've tried adding a 5 second "reset_tout" delay but that doesn't seem to help. Is there a more detailed level of debug I could look at to find out what's going wrong? Looking at the C027 board it's difficult to correlate when the problem occurs with the behaviour of the LEDs, but it is something to do with the end of the copy and the reset I guess. What else could I do to make this reliable?
Discuss and develop the mbed SDK.
Now moved to:
https://github.com/mbedmicro/mbed/issues/992
posted by Rob Meades 23 Mar 2015
Only problem is no-one is answering on github!
posted by Rob Meades 24 Mar 2015
11 years ago.
I provide this as an answer:
Thanks for reporting. As that script is part of mbed SDK on gihtub, can you report it there. It's easier for reference (we can reference issues in the commit messages, github tracker issue also sends noficiation to all of contributors and us), as oppose this does not. Thanks
