11 years ago.
seeeduino arch pro : needs to poweroff to reinit dhcp. Why
issue using arch pro with imac / yosemite
when using EthernetInterface, I need to poweroff/poweron to get an ip address (pressing button is not enough, as it is on original mbed lpc1768) : arch pro stay in eth.init()
any ideas ?
BTW while booting a new bin, there are a lot of firmware log on serial port : block: 1 block: 2 block: 3 block: 65 block: 66 block: 67 block: 68
11 years ago.
Thanks for reporting the issue.
To fix ethernet halt issue, try to add the following function in your program
extern "C" void mbed_mac_address(char *mac)
mac[0] = 0x00;
mac[1] = 0x02;
mac[2] = 0xF7;
mac[3] = 0xF1;
mac[4] = 0x91;
mac[5] = 0x9F;
The issue is: EthernetInterface library will try to get a mac address through semi-host, but semi-host is not supported by Arch Pro.
The firmware log should be turned off. We will fix it in next release
Thanks, Yihui
